Print and Cut is way off
jazzimat
Post by jazzimat »
I have a GCC Jaquar V cutter. I can contour cut with the software that came with the cutter, Great Cut 4, but when I cut thru SCAL 5 Pro this is what I get. It's way way off and I don't know how to fix it. I don't understand why it's doing this.
IMG_3068 (3).jpg (32.21 KiB) Viewed 40 times
Re: Print and Cut is way off
Unfortunately, I don't own a GCC so I cannot test out this issue. If it were me, I would first go to my GCC dealer for support. If that's not an option (perhaps you bought the cutter used), then go to a GCC forum or FB group and see if someone there can help you with this. If you cannot find help that way, then start a support ticket with SCAL using this link: http://craftedge.com/support/support_form.php
Good luck!
pajinki
Post by pajinki »
Have you heard anything from this? I have a GCC Expert II LX and I have the same problem. I got in contact with GCC and I've been waiting for a week for a fix.
It's pretty upsetting.
I recommend you ALSO submit a ticket to Craft Edge regarding this issue. It helps prioritize fixes when more and more people report them.
