Craft Edge
Sure Cuts A Lot Forum
It is currently Fri Feb 28, 2020 10:10 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 210 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20, 21  Next
Author Message
PostPosted: Sun Sep 13, 2009 6:28 pm
Ok, i followed your instructions and unfortunately, it happened again.
What happens is; the top right of the screen turns black (where the tools are), the drop down arrows turn into 6's, and if i try to type in the window, another window pops up but no letters. It just all goes haywire and needs to be closed in order to restart and work again.
Top
 Profile
PostPosted: Sun Sep 13, 2009 7:02 pm
Location: TX Win 7 Home Premium, SCAL2.008, Inkscape 0.46
Have you ran Windows updates lately? It almost sounds like maybe you don't have the latest .NET release. Just a thought!
_________________
Top
 Profile
PostPosted: Sun Sep 13, 2009 7:16 pm
We have it automatically set up to update.
It just happened a few times again. So frustrating! Do you think maybe there is a time limit to how long i can use the software before it shuts down?
Top
 Profile
PostPosted: Sun Sep 13, 2009 7:18 pm
No! Even the trial doesn't care how long, it just cuts the lines in your cuts! That really sounds like you may need to run updates - it would apply the latest .NET, security patches, etc. I would try that next.
_________________
Top
 Profile
PostPosted: Sun Sep 13, 2009 7:26 pm
I'm noticing that when it took longer to freeze when i first started but then it kept freezing more quickly as time went on. It's really weird.
My hubby is a computer wiz and has all the updates, scans, virus protections, etc etc, loaded here. He can't figure it out either.
I assumed it was a glitch in scal2 but no one else seems to have the same problem. Very frustrating.
Top
 Profile
PostPosted: Sun Sep 13, 2009 7:44 pm
I have Cricut version 1.32 and SCAL 2.004 and have continual freezes when cutting. Have tried one item over and over, and it cut one out of 4 without freezing. I have tried everything. One thing for those whose computers are riving up to 100% check out cidaemon.exe on line, it might help. Any ideas to solve the freeze issue? Thanks.
Top
 Profile
PostPosted: Sun Sep 13, 2009 7:50 pm
Ok, seems as if someone else is having the same problems. Maybe someone from craftedge can help us here?
Top
 Profile
PostPosted: Mon Sep 14, 2009 4:56 am
If cidaemon.exe is the process running your CPU up to 100%, it is only a critical process to run Microsoft Indexing Service, which is not required for your system to run. My experience with MIS is it isn't worth having it running because I found it did suck all of my system resource's...inefficiently.
Disable the Indexing Service: You can turn indexing off by stopping the service in services.msc (Go to Start > Run and type services.msc or right-click your My Computer icon and click Manage > Services and Applications > Services, scroll down and highlight Indexing Service then right-click on it and select Properties then Manual under Startup Type and click OK. Set it back to Automatic if you ever want to start up the service again!
_________________
Top
 Profile
PostPosted: Mon Sep 14, 2009 6:40 pm
I have a question... I dont have the upgrade yet, am considering it, however Im going to get a new computer this month.
I currently have XP but will more than likely get the vista with upgrade to windows 7.
How will that affect my current SCAL configuration? I dont know what to do first.
thanks!
Top
 Profile
PostPosted: Tue Sep 15, 2009 12:23 am
I purchased SCAL but I did not understand that 2.0 was the upgrade. I downloaded it only initially and activated it with my serial number. Then I realized it was the upgrade and downloaded 1.0 but it will only give me the trial version and won't allow me to use my serial number to activate it. So now I only have the upgrade without 1.0. I only have the trial version. Help. I guess I was not very computer savvy. Anyone have any ideas.
Top
 Profile
Search for:
Jump to:
