Sure Cuts A Lot 4 Released for Windows & Macintosh
http://forum.surecutsalot.com/viewtopic.php?f=67&t=40676
Page 1 of 5
Author:  craftedge [ Wed Nov 19, 2014 10:52 am ]
Post subject:  Sure Cuts A Lot 4 Released for Windows & Macintosh
- New enhanced interface
- Type on arch
- Snap to objects
- Rotated duplicate
- and more!
Pro Features
- Tiling
- Duplicate cutting
- Cut by color
- Color layer alignment
- 3D shadow
- Import DXF, PLT
Special Introductory Pricing:
For more information
Sure Cuts A Lot 4
Sure Cuts A Lot 4 PRO
Author:  dmpecci [ Wed Nov 19, 2014 11:43 am ]
Post subject:  Re: Sure Cuts A Lot 4 Released for Windows & Macintosh
Author:  sstehman [ Wed Nov 19, 2014 12:21 pm ]
Author:  BigDude [ Wed Nov 19, 2014 12:41 pm ]
Author:  sstehman [ Wed Nov 19, 2014 3:42 pm ]
Author:  palz11 [ Wed Nov 19, 2014 3:50 pm ]
Author:  sstehman [ Wed Nov 19, 2014 5:01 pm ]
Author:  cydnew [ Wed Nov 19, 2014 6:47 pm ]
Author:  sandyhoy124 [ Wed Nov 19, 2014 10:17 pm ]
Author:  susibi [ Wed Nov 19, 2014 11:51 pm ]
Page 1 of 5 All times are UTC - 8 hours
http://www.phpbb.com/
