It is currently Thu Feb 27, 2020 10:02 am
PostPosted: Fri Sep 13, 2019 9:45 am
Hi, I don't know what I did but everything is in outline. Even if I import stuff I've used before, it is in outline. I'm against a deadline and going crazy. Any help is greatly appreciated.
Di
PostPosted: Sat Sep 14, 2019 7:03 am
On the Document Panel you'll see a setting called Show Outlines Only - uncheck that.
If that doesn't fix it then:
(1) On the same panel, make sure Workspace Alpha is set to 100
(2) Select any shapes that are still outline only and on the Fill & Stroke Panel, make sure the Fill color is set to Color and, just to the right click on the little color box to set a color.
(3) Also,while the shapes are selected, make sure the Opacity (also on the Fill & Stroke Panel) is set to 100.
