It is currently Sat Feb 23, 2019 7:42 pm
PostPosted: Thu Jul 12, 2018 9:00 am
Why does my project disappear unless I hover over the image in SCAL4?
PostPosted: Thu Jul 12, 2018 12:15 pm
The most obvious possibility is that both the Fill and the Stroke are set to None or White?
PostPosted: Thu Jul 12, 2018 12:26 pm
My fill and stroke are ok; this is something that has just changed within the last couple of days. I must have accidentally changed something as my old projects that were once ok are now disappearing until I hover over them.
PostPosted: Sat Jul 14, 2018 6:02 am
Please bear with me as I try to figure out what's happenening. I need you to select the object and then show me the Fill and Stroke settings assigned by taking a screenshot of all of this. The only other thing I can imaging is the Opacity settings on either the Fill & Stroke or on the actual Workspace itself (which is a setting on the Document Panel... called Workspace Alpha).
PostPosted: Mon Dec 31, 2018 11:16 am
I am having this same issue right now and its driving me crazy because I cannot design like this on the work space.
What is the deal?
Im importing SVG files and they are only showing up if I hover over them.
It has nothing to do with the art palette of fill and line because that does nothing.
PostPosted: Mon Dec 31, 2018 1:04 pm
First of all, on the Document panel on the right, make sure you do NOT have Show Outlines Only marked. Also, on that same panel, mak sure Workspace Alpha is set too 100. If that doesn't fix things, then please email the file to me at smccauley45@cox.net or you can upload it here.
