Problem with svg
Problem with svg
I was sent an sag file from a buddy , but when i go to cut it, it seems to trace the lines several times, causing it to cut through the vinyl causing a mess. I was wondering if there was a way to correct this, or re-format to make it work better.
Re: Problem with svg
Sounds like there are multiple lines. Put it on your mat, highlight and then go to "Object" and ungroup. If there are multiple layers you should be able to eliminate the extras. This happens fairly often and once you see how many layers there are it will make more sense to you. Jan
