Hello
I have ZERO experience with cutters and SCAL and want to make decals for the cat resue that my wife helps with so they can raise funds to help the kitties
what would ( in your opinion ) be a good one to get that obviously works with SCAL
granted I know everyone has their favourite machine for whatever reason but as I know nothing at this point any help would be great
also is it worth the savings by buying a used cutter ?
thank you in advance
David C
what cutter to buy ?
Re: what cutter to buy ?
i have a uscutter SC series cutter that works with SCAL. actually you will get the pro software when odering your cutter. I love it. It is a 24" cutter.
Theresa
If you ever want to cut chipboard, you may want a cutter that can handle cutting thick material. If you only want to cut cardstock, a simple cutter would be the say to go. You have to think about what you will want to use one for before buying one.mrfibble wrote:Hello
David C
Here's a chart:
http://die-cutting-machines-review.toptenreviews.com/
regina_rhinestones
Blog: http://tellabling.blogspot.com
My Etsy Shop: http://etsy.com/shop/CraftyChipboard
My Youtube: http://youtube.com/user/tellabling
cheers for the replies
it would be used for vinyl only ....
im probably going to go with this one "USCutter SC Series"
anyone used or have one ? thoughts ?
cheers
david c
cheers
david c
If you are just cutting simple patterns out of colored vinyl, go for it. Trust me, you won't want to go through the rigors of learning to cut different substrates, you'll have your hands full.
24" Cougar Pro with ARMS that does not work
SCAL 3.057
CorelDraw X5
Illustrator CS5
Win 7 64 bit
Epson Stylus Pro 7600
SCAL 3.057
CorelDraw X5
Illustrator CS5
Win 7 64 bit
