Hope someone out there can help me out. I just received the scal 3 and am working with it now. I'm looking for a svg file for the target mailbox-not to make the whole mailbox, just the cut outs to fit onto the mailbox. I have a lot to make for preschool and this would be much easier. I found one but it was a MTC. Can I convert that and then import it or does someone have one already for this. I have the silhouette cameo for cutting.
Sharon
new user-converting files-target mailbox
Re: new user-converting files-target mailbox
If you have MTC and yes you can convert it for you own use open it up in MTC and select the item then right click and select export there are several options there select the one that says sel. to svg file then you can import that into Scal3
