It is currently Wed Sep 19, 2018 10:27 pm
PostPosted: Tue Jan 09, 2018 2:23 am
I am using SCAL 4 with Corel Draw, I have designs which will be printed then scan and cut, How do i export exact registration marks to Corel draw and send them to the printer.
Please advise.
TIA
JK
PostPosted: Tue Jan 09, 2018 9:23 pm
This is a quick answer to what will probably be a little more involved.
There are two ways to export the reg marks: Use SVG which has an option to add the SCAL reg marks. Or you can use a Print to PDF option, such as Microsoft Print to PDF or the similar one that's part of Mac's O/S and make sure mark the Print registration marks option in the print settings window.
PostPosted: Tue Jan 09, 2018 11:10 pm
Hi Sandy,
Thanks for the reply, One question is all my designs are in CMYK, but when i import and export from SCAL the output is in RGB. I do not see any option to change that, Any advise. Thanks.
PostPosted: Wed Jan 10, 2018 10:15 am
Yes, and this is the number one reason why Corel Draw and Illustrator owners will often prefer to use those programs for printing their PNC projects. Thus, the reason why I mentioned two ways to get your registration marks exported to Corel Draw.
I wrote up a detailed method that we recommend for those who own KNK cutters (the ones I support). It's Section 11.07 in this user manual and it SHOULD work for you, even though I don't know which cutter you own.
