I am having this problem with butterfly fonts/dingbats. Butterflies are one of my favorite things so everytime I come across some I want to save them. Problem is that I've come across several that are just called "butterflies" and I'm unable to save them all b/c they have the same name. I've tried renaming but once it gets into the Fonts folder it reverts back to its original name and it won't save b/c there's already another one named butterflies. Any ideas how to get around this? Here are links to two that I recently have come across with the same butterflies name:
http://www.houseoflime.com/dings/butterflies.htm
http://www.dafont.com/butterflies.font
Fonts with the same name
Re: Fonts with the same name
can you rename one of the ones that is already loaded on your computer? Or try saving it to another folder and then renaming it??
I was able to save it in another folder and I can just temporarily install it via AMP when I want to use it since I can't rename fonts in the fonts folder...so dumb! But at least I've found a way to use them.
~Nicole~
