I cannot get it to work.
What am I doing wrong??
George and Basic Shapes already on Cricuts!
Re: George and Basic Shapes already on Cricuts!
I tried the paperclip and couldn't get it to work. I'm going to try some crafting wire that I have around here somewhere if I can find it. If that doesn't work, I'll attempt the cardboard and aluminum foil method.
Brittany
http://svgfiles.blogspot.com/
Decided to go ahead and try the "cereal box" method and I got it to work.
Brittany
Cardboard and foil is probably the best way to do this.
Can someone send me a template of the exact size and shape to cut the foil?
I have tried everything and cannot get it to work..... I really want to try this...
Thanks a million!
Candie
Thanks a million!
Candie
If I get a chance, I will draw something up tonight.
Here is a picture of what it should look like. This should work with the foil facing you or away from you. Only three slots need to be connected.
I got it to work!!! I have been wanting a George cart for a while because a lot of the patterns/designs out there use it. It was so easy, I used thin cardboard and foil tape that we had left over from a home improvement project. Thanks a million Todd! Now I have to go play. . .
J Marie
Hi Todd,
I'm new to the boards and tried making this out of several things: cereal box and foil, actually cut up an old credit card and used "flash" tape for roofing.
I made the "silver" portion only hit the "Pins" at 2, 3 and 5.
Tried it counting from left to right AND then right to left. I used the front part of the pins and the back part of the pins.
Nothing is working.
I don't have any measuring tool that is as exact / specific as the measurements you gave on the "template" example.
Any suggestions?
Winniebear
Nothing is working.
Any suggestions?
Winniebear
Can you use a pin on another cartridge to measure with?I don't have any measuring tool that is as exact / specific ....... the "template" example
Just a thought.
