keyboard shortcuts
Posted: Tue Apr 30, 2019 5:32 pm
by TLC custom stickers
hi peeps
i am new to scal i have previously been using an outdated version of artcut. im just after a list of keyboard shortcuts to make life a little easier.. thanks in advance tash the hobbiest
Re: keyboard shortcuts
Posted: Wed May 01, 2019 6:14 am
by SandyMcC
Here you go:
https://www.iloveknk.com/Support/Tutori ... rtcuts.pdf
And then, if you ever do need a detailed user manual (or other tutorials/videos) for any particular function, here's a link to my Support page for SCAL:
https://www.iloveknk.com/support/sure-c ... l-support/
Posted: Wed Jun 26, 2019 4:49 am
by cpking
Hi SandyMcC,
Thanks for sharing your awesome helpful PDF for Keyboard shortcuts .
Posted: Fri Jun 28, 2019 8:30 am
by SandyMcC
My pleasure!
Posted: Fri Jul 26, 2019 4:57 am
by Snijderke
Hi Sandy,
nice to see the short-cut tabel. But I do n't see a short-cut for "Close project" and no for "close all projects". ???
Posted: Fri Jul 26, 2019 9:20 am
by SandyMcC
Aha! Thank you! That shortcut was obviously (and logically) added in SCAL5 since SCAL4 didn't allow more than one project to be opened. I missed seeing it when comparing the two programs and updating the table. I'll get it added. If you find others, please do let me know.
Sandy
Posted: Wed Jul 31, 2019 11:59 pm
by SteveMyers
F1 key: Get help on a selected command or use the Office assistant.
Shift and F1 Key: Review text formatting.
F2 Key: Move text or image.
Shift + F2 Key: Copy text.
F3 Key: Insert an autotext entry.
Shift + F3 Key: Change the case of the selected text.
F4 Key: Perform last action again.
Shift + F4 Key: Perform a Find or Go To action again.
F5 Key: Displays the Go To dialogue box. You can also get to Find and Replace from here.
Shift + F5 Key: Move to a previous revision.
F6 Key: Go to the next frame or pane.
Shift + F6 Key: Go to the previous frame or pane.
F7 Key: Launch the Spell Checker.
Shift + F7 Key: Launch the Thesaurus.
F8 Key: Extend the current selection.
Shift + F8 Key: Shrink the current selection.
F9 Key: Refresh.
Shift + F9 Key: Switch between a field code and its result.
F10 Key: Show KeyTips.
Shift + F10 Key: Display a Shortcut Menu (same as right-clicking).
F11 Key: Go to the next field.
SHIFT + F11 Key: Go to the previous field.
F12 Key: Open Save As, equivalent to tools menu.
Shift + F12 Key: Save document, equivalent to tools menu.
Ctrl and A: Selects all in the current document.
Ctrl and B: Bold text.
Ctrl and C: Copies the item or text.
Ctrl and D: Displays the Font dialogue box.
Ctrl and E: Switch a paragraph between center and left alignment.
Ctrl and F: Displays the Find dialog box to search the current document.
Ctrl and G: Displays the Go To dialog box to search for a specific location in the current document.
Ctrl and H: Displays the Replace dialogue box.
Ctrl and I: Italicize text.
Ctrl and J: Switch a paragraph between justified and left alignment.
Ctrl and K: Create a hyperlink.
Ctrl and L: Left align a paragraph.
Ctrl and M: Indent a paragraph from the left.
Ctrl and N: Create a new document.
Ctrl and O: Opens a new document.
Ctrl and P: Prints a document.
Ctrl and R: Switch the alignment of a paragraph between left and right.
Ctrl and S: Saves a document.
Ctrl and U: Underlines text.
Ctrl and V: Pastes the copied item or text.
Ctrl and X: Cuts the selected item or text.
Ctrl and Y: Redo the last action.
Ctrl and Z: Undo the last action.
Ctrl and Enter: Insert a page break.
Ctrl and F2: Select Print Preview command.
Ctrl and F4: Closes the active window.
Ctrl and F6: Opens the next window if multiple are open.
keyboard shortcuts
Posted: Sat Aug 17, 2019 4:44 pm
by MichaelTiera
I like keyboard shortcuts a lot since they allow me to save so much time and nerves. Currently, I have to create lots of graphics in Inkscape with lots of alignment stuff. Alignment with the keyboard shortcuts on the keypad align top/bottom/center... works perfectly for me. There is just one problem: I really often have to change "Relative to" between "Last selected" and "Page". Therefore, I always have to open the Align and Distribute view and change it appropriately with the mouse. I did not manage to give that a keyboard shortcut. Can anybody tell me, how this can be accomplished?
