It is currently Sun Jan 26, 2020 9:35 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
PostPosted: Sat Apr 27, 2019 7:49 am
I set the origin point close to right hand corner of vinyl but why is word, THE, so far, almost 4 inches away from the side of the vinyl? As you can see, is quite a lot of waste. That said I did cut off the larger section, as might come in useful for future projects.
I have four words to cut out, the height of word THE including line squares is 29cm the width of vinyl roll is 60cm. If I reduce the size of the line up squares and the height of THE I can still maintain an effective word size. I could then maximize the economical use of the vinyl by having one word under the other. I'm wondering about boarder size or whatever I should leave to do this and still not sure about this setting of the origin point in regarding setting up to cut two words parallel to each other?
I'd like to know the procedure to reduce size of word THE and have word HIT under it, all letters of both words the same height. Is there some way to apply a template to fit all four words so letters all same height and 2 words under each other on mat and can cut from vinyl roll?
Thanks.
PostPosted: Sat Apr 27, 2019 7:50 am
More pics
PostPosted: Mon Apr 29, 2019 11:28 am
There are different settings which control where something will cut. Also, depending on which cutter you own, the aligning origin might be based on the location of the blade tip or the location of something else on your cutter, such as a laser light. Based on your screenshot, however, that little square in the upper right corner, should be cut at the origin regardless of whether you have WYSIWYG or Origin Point selected in the Cut Settings window, since that shape is positioned at the origin on the screen, based on you being in Landscape mode.
PostPosted: Tue Apr 30, 2019 11:03 am
OK I'll look more into aligning two line of text on Wednesday and will get back to the forum saying how I got on.
PostPosted: Sat May 04, 2019 1:18 pm
Sorry got held up will try to look into this Sunday.
PostPosted: Mon May 06, 2019 11:25 am
I've installed Win 10 upgrade learning my way around it,hence the delay.
To make economic use of my vinyl, 24 inches wide. I'm intending to cut two words under each other. I open word THE, then enlarged size of cutting mat and repositioned THE a little. I tried to run a 2nd SCAL so could open word HIT and copy and paste it onto new enlarged mat, didn't work.
How can I copy HIT word that is in a saved project, copy and past it into new project?
Thanks.
PostPosted: Tue May 07, 2019 7:34 am
Since you're using SCAL5, you can just use File>Open to open another SCUT5 file and then copy/paste your design over to the first file. You'll see tabs for your two projects here:
PostPosted: Wed May 08, 2019 10:51 am
OK brilliant! Thanks, will look into on Thursday.
PostPosted: Mon May 13, 2019 9:02 pm
Its a new topics for mine so i read it fully and learn something .
PostPosted: Sun Jun 02, 2019 7:44 am
The attachment D1.PNG is no longer available
I've done this but the second word, HIT didn't quite work out could you have a look at screenshots and advise please?
Screenshot 1 Started a new project, so can line up two words to maximize use of vinyl roll.
screenshot 2 Open project - word THE, edit, select all, copy.
Screenshot 3 Open new project, edit, paste in place.
Screenshot 4 Move word THE off mat onto clipboard.
Screenshot 5 Open project - word HIT, edit, select all, copy.
Screenshot 6 Paste into place in new project ( dual row of words ) n
Screenshot 7 Reposition word HIT, the little line up squares are smaller than the originals I copied.
Thanks. More screenshots in next posts.
