Craft Edge
Sure Cuts A Lot Forum
It is currently Sun Feb 17, 2019 1:34 am
Author Message
 Post subject: Cutting Lines
PostPosted: Sun Sep 09, 2018 8:26 am
Hi...I'm new to Sure Cut and have a silly question. How do you assign things to cut and not cut but print. I use Silhouette now and just bought a silver bullet but can not figure this step out.
Thanks for the help!
Top
 Profile
 Post subject: Re: Cutting Lines
PostPosted: Mon Sep 10, 2018 9:36 am
Select a layer and, on the Style Panel, you select what you want to do with that particular layer. Here's a PDF I put together that explains each choice:
http://www.iloveknk.com/Support/Tutoria ... n-SCAL.pdf
Then, I also have a user manual that will explain all of the various SCAL5 functions in detail. Try using it as a reference book when you're not sure about a particular function but don't hesitate to post back here with questions and issues:
http://www.iloveknk.com/support/sure-cu ... l-support/
_________________
Manager of Customer Relations and Education for KNK USA
Top
 Profile
PostPosted: Mon Sep 10, 2018 10:06 am
Thank you so much! I thought it might have to do with the layers after I thought about last night. I'm so used to using the Silhoutte software it was throwing me off. I will review the things you recommended.
Thanks for getting back to me
Deanne Lund :)
Top
 Profile
PostPosted: Mon Sep 10, 2018 3:40 pm
You're welcome! And switching from one cutting program to another is always a bit of a battle at first. Most functions are preformed differently, nomenclature is mostly different, learning where things will cut can be more difficult to grasp. But eventually it all comes together and you're good to go!
_________________
Top
 Profile
Search for:
Jump to:
cron
