Export to AI or EPS
SPI
Export to AI or EPS
Post by SPI »
Hi, I purchased "Sure Cuts A Lot 4". My screen printer would like the file as an illustrator ai or EPS file. Can somebody confirm that you can export to these file types with the extension - "Adobe Illustrator Export Plugin for Sure Cuts A Lot PRO (Windows). " Does it work well without any issues?
Thanks!
Re: Export to AI or EPS
best bet is to go to support@craftedge.com and fill out the support form. This will go directly to the designer of scal who will provide you with an answer.
You can only export jpg, png, ttf, bmp and svg if any of your programs can open them. Illustrator does open svg files.
You can also print to PDFand most programs that except EPS and AI, also accept PDF. Go to File>Print and see if you have an option regarding PDF. If not, then you can find free "Print to PDF" applications on the Internet. I have more solutions if you get stuck so definitely post back!
SPI
Post by SPI »
Thank you! I printed to PDF and I will see if this works. I emailed support@craftedge.com but I have not received a response yet.
