Scal4 cut order
Ryest
Scal4 cut order
Post by Ryest »
Hi all
Can anyone tell me if there a setting that can be changed for scal4 to cut in an order of what is on the screen
ie if I have a 600mm x 600mm mat size with 4 different designs to cut, it seems to cut a portion of 1 design (say top left) then move off and cut a portion of the lower right, then a single part of the top right and so on.
Is there a way of just having it cut one design then move on to the next. It just seems to be a lot of unnecessary movement.
Thanks in advance
Ryan
jrichards
Re: Scal4 cut order
Post by jrichards »
It cuts in the order that items were placed on the mat. I am not aware of any way to change that. Maybe someone will come along with more information.
harry56
Re: Scal4 cut order
Post by harry56 »
Do you have the Auburn symbol in svg file?
gclub
Snijderke
Re: Scal4 cut order
Post by Snijderke »
Ryest wrote:Hi all
Thanks in advance
Ryan
maybe you can select only the first item to cut. Next select the second item to cut .... I hope that will help.
