It is currently Thu Feb 21, 2019 7:03 pm
PostPosted: Mon Mar 27, 2017 2:06 pm
I have the older Cricut machine? Which version can I use?
I'm also considering upgrading to a Cricut Explore. Does this software work with that?
PostPosted: Mon Mar 27, 2017 10:24 pm
If you are using the Cricut Explore models you will be able to do this with version 4 of Sure Cuts A Lot
https://www.craftedge.com/tutorials/designspace/designspace.php
Version 2 of Sure Cuts A Lot was the last version we created to cut directly with the older Cricut models (Personal, Expression, Create, Cake).
Sales of version 2 ended in 2011, but if you had purchased that version back then, you can use the latest version 4 of Sure Cuts A Lot to create your design and then send it to version 2 for cutting as shown here
https://www.craftedge.com/tutorials/sendtoscal2/sendtoscal2.php
http://www.craftedge.com
PostPosted: Tue Mar 28, 2017 8:06 am
Thanks for the information.
I also noticed there was another post on getting SCAL4 to work with the older Cricut models using a separate plugin here
http://forum.surecutsalot.com/viewtopic.php?f=6&t=42102
I tried it out and this worked!
I will be able to get a little extra life out of my old Cricut and then probably upgrade to their newer Explore.
