Cameo 3 not found
leslih
Cameo 3 not found
Post by leslih »
Hi
I have been using scal for years Only one I will use. My main machine broke so I pulled out my old dusty cameo. It wasn't working right but it was communicating with scal no problem. I upgrade to the cameo 3. I have it set up to go and it won't communicate with scal. I checked for scal updates. It says I am up to date. Is there a driver I need? I looked in the list but didn't see one.
craftedge
Re: Cameo 3 not found
Post by craftedge »
Make sure you have the latest update installed from here
http://www.craftedge.com/updates
Then go to the Cutter menu, choose Manage Cutters and add the Cameo 3
top1percent
Post by top1percent »
I'm having the same issue running SCAL3Pro ver3.081. I haven't found an updated version other than shelling out the $$ for SCAL4Pro... Is there no way to use a Cameo3 with SCAL3Pro?? If not, I may return the Cameo3 and just buy an older Cameo..
