My patterns come out inconsistant sizes
I have some pattern that i have purchased a while back. I have used these pattern without problems in the past. Recently, when I have opened these same pattern in my scal the sizes are not consistant. Example, if i am trying to cut out a body, the head would be small and the legs would be large. They do not match to make a perfect body. Have I personally done something to change these design? What can I do to fix this problem. I would really appreciate any help or advice on this matter. I have several patterns that I would love to use again. Thank you in advance.
Re: My patterns come out inconsistant sizes
I'm also having a problem with the size of my imported SVG files. Everything is about 40-45% smaller than it should be, and I haven't changed any settings since upgrading to ecal2. I'm hoping we get an answer to this problem, but I won't hold my breath. I'm going to try downgrading to v1.5 to see if it has to do with the new software.
I figure out the problem I was having, but I'm not sure if it will help you. I went to the file menu and selected 'edit', then preferences. My SVG DPI was set to 90 (Inkscape) so I changed it to 72 (Adobe Illustrator), which corrected the scale problem. Most of the files I get have been created in Illustrator. Maybe checking your settings will help. If you're getting you files from different sources made in different programs it could cause the size difference.
I hope it works for you. Like I said, I have use these designs before and they were all the right proportions. The only thing I can think that I had done was transferred them to my new laptop. How that would make a difference I don't know. Ugh hope that someone can help me out.
There are settings for opening SVG files. I think it depends on what program created the SVG. If you have your computer set for Illustrator SVG and the SVG was created in a different program, that might cause a size adjustment.
