I have two PCut machines. Up until a few weeks ago, they both worked with scal3 like champs.
Now when I go to "cutter" and then "cut with uscutter" - it goes through the motion except cutting and I get the pop-up
"cutting data was sent to cutting machine" but no action.
Anyone else having an issue like this??
US Cutter PCut
Re: US Cutter PCut
make sure you did not change the setting on your machine by mistake.
Re: US Cutter PCut
also make sure windows (or your OS) has not changed/lost your USB ports
if the OS says the cutters are on port 3 and scal thinks they are on port 2 they won't "see" each other.
Gaz
Gaz
Computer:IMac running Mojave
Re: US Cutter PCut
Fixed YAY!!!
Thanks, support team!
