Welding question
Welding question
I made a title (which I will share if I ever get it to work) in Inkskape, placing the letters in an overlapping fashion. Then I imported it to SCAL and it looks as if it should be welded but it still cuts out the letters individually. Obviously, I've missed something here. Can anybody tell me what I'm doing wrong?
Re: Welding question
merely overlapping the letters does not weld them together.
I'll put the directions in a new post for everyone to see. Hope it helps you out!
To weld the letters after you have them overlapped
1. Edit>Select All
2. Path>Object to Path
3. Path>Union
1. Edit>Select All
3. Path>Union
Thanks for the advice. I neglected to mention that I had already done the path/union thing and it still didn't weld when it came time to cut.
can you send me the file and I will see if I can fix it or see what is wrong stbernard11 @ verizon.net (no spaces)
Laurieinaz wrote:Thanks for the advice. I neglected to mention that I had already done the path/union thing and it still didn't weld when it came time to cut.
Beanie ~~Been There Done That~~
I have welded a word with Inkscape. How do I open it in SCAL?
"Import"
Under your File tab in SCA you'll see the Import option.
I'm sorry. I'm still not getting it. I've read the tutorial and I got a weld to work once, but I don't know why. Here's what I've done.
Overlapped my letters.
Select all
Path > Object to path
Path > Union
Save
When that didn't work, I tried the above on each individual letter. Still not working.
Any thoughts?
Select all
Path > Union
Save
Any thoughts?
