I understand when I see a file with solid lines they are the lines that are cut and the dotted lines are the scored lines-does the cricut scores those lines? I don't understand-sorry if this is a really stupid questions. Still in the learning phase.
Thanks! Andie
Cut lines and score lines
Re: Cut lines and score lines
andie,
The dotted lines will usually score in a dotted pattern.
The solid lines you should be able to separate the lines into layers -cut/score these first before cutting the rest of the box out. Set your blade depth at 1 and your pressure at 1 and "cut/score" the lines then reset your blade depth and pressure setting appropriately according to the paper you are using.
hth
hth
that really helps thanks!!!
