Cutting multiple copies of same image
Things we need you to know
LuraJean
Post by LuraJean »
I am attempting to cut pink ribbons and want to cut within the ribbons and cut multiples of the same image. Do I need to duplicate each image to fit the page? If I add text to each image, will the cricut recognize this as well
Re: Cutting multiple copies of same image
Hi, you do not say which version of SCAL you have, but if it is any of the newer ones you would use the Duplicate function Object Duplicate.
this video is how to use the function to make columns and rows as many as you like although it only doscolumsn, but just add the rows as the video shows.
viewtopic.php?f=18&t=32617
If you have an older version of SCAL there is a function called fill page, but I don't remember exactly where it is but is will fill the mat with the image of your choice. Hopefully someone will come along and remind us.
NOTE: it is always helpful and faster if you will include the version of SCAL.
mitsim
Post by mitsim »
You can certainly use the duplicate, but if you want to just fill the page with a particular image, you can go to copy, then paste (auto-fill), and it will fill the page with whatever image you have copied.
dragonlord666
Post by dragonlord666 »
I'm reading the OP as they want to cut a ribbon shape but have cutouts INSIDE that ribbon
like the attached. not sure what KIND of ribbon is meant so image has both types I often use
a "pin" ribbon and a straight one.
Ribbon Test.png (62.4 KiB) Viewed 7243 times
this was done in inkscape but should be able to be done in scal3
Gaz
Computer:IMac running Mojave
LuraJean
Post by LuraJean »
BTW, I am using SCAL2 and thank you for all your responses!
dragonlord666
Never used Scal2 but I'm sure we can all muddle through.
so which ribbon was it - bow or straight or neither LOL
Gaz
