Craft Edge
Sure Cuts A Lot Forum
It is currently Sun Feb 17, 2019 11:47 pm
Author Message
PostPosted: Tue Sep 04, 2012 1:32 pm
Not sure if its already been mentioned as not had time to keep up on the forum, but just in case not..
SCAL 3.030 is out which has some bug fixes, it now imports bitmaps embedded in SVG's (still a little bit buggy though) and enables you to send an SVG directly from Inkscape to SCAL to cut by going to Extensions->Export->Send To Sure Cuts A Lot 3
You need to install the Inkscape plugin to do this..
PC - http://www.craftedge.com/bin/SCAL3_InkscapePlugin.exe
Mac - http://www.craftedge.com/bin/SCAL3_InkscapePlugin.zip
Once you install the plugin you can design your file in inkscape and select the export option to send it to SCAL to cut without all that saving and importing nonsense - very, very, VERY pleased to see this
_________________
Top
 Profile
PostPosted: Wed Sep 05, 2012 3:44 am
Yeppers...have been using it for several days now and it is WONDERFUL!!!! Brandon will be posting it on the Craftedge page...just hasn't done it yet...It makes it SUPER SUPER SUPER simple to send a file to SCAL3......Brandon flat out ROCKS I tell ya!!!!
Top
 Profile
PostPosted: Wed Sep 05, 2012 10:31 am
I contacted him about a plugin version quite some time ago, I created an inkscape plugin to send the file across but SCAL was unable to automatically open it.
But Brandon has put together an automatic plugin install file which is much better than messing about installing mine manually.. Now I just need to figure out how to remove mine again because I have two send to signcuts LOL
_________________
Top
 Profile
Search for:
Jump to:
cron
