Using Layers in SCAL
- Location: Southern California, SCAL 1/2 Inkscape, Illustrator
- Contact:
Re: Using Layers in SCAL
Go to the My Crafty Life, dan99.blogspot.com has an excellent tutorial for using inkscape. You don't want to use layers. You really need them all on one layer. He is so easy going and understandable. I first listen and watch tutorial, then listen again and write it down. Also if your monitor is big enough you can do a split screen and follow him. His tutorials are usually about ten minutes. He has a ton of them on different things.
I was just going to suggest that very thing Silvertip. Once on his blog look under tutorials. He has alot of great things there.
"Imagination is the one weapon in the war against reality" - Jules de Gaultier
