It is currently Wed Jun 26, 2019 12:20 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jul 01, 2012 8:54 am
Oooo.. I spotted a slight error..
I will adjust and upload again, sorry about that..
PostPosted: Sun Jul 01, 2012 9:08 am
here they are, just SVG's, I figure its easy enough to import them ;)
invite-flaps-5 x 7 - rounded.svg [3.18 KiB]
Downloaded 216 times
invite-flaps-5 x 7.svg [2.74 KiB]
Downloaded 207 times
The little corner cutouts were 90 degrees on the original which would have likely stuck out a bit after folding, I just made them a bit greater than 90 degrees so it will sit better when folded.
Enjoy
PostPosted: Sun Jul 01, 2012 12:48 pm
Wow! Thank you SOOO much! it looks fabulous. I am so impressed with your talent and your willingness to share it! :)
PostPosted: Sun Jul 01, 2012 1:31 pm
You are very welcome :)
If you use it don't forget to share a picture or two ;)
PostPosted: Tue Feb 26, 2013 9:08 am
QUESTION on the envelopes with flaps - in preview it appears it is going to cut 2 rectangles basically - I tried to weld them together and preview again and it looks the same - how can I get this to not cut out the inside lines and just the outline of the envelope - I assume you score the inside lines to fold --- am I having a brain freeze or what ?? Thanks for any help
Regards,
Cathy
PostPosted: Tue Feb 26, 2013 9:49 am
Regards,
Cathy
I just go to OBJECT and the UNGROUP and then would delete the inside rectangle, then cut.
PostPosted: Tue Feb 26, 2013 10:02 am
I think I have the envelope problem fixed BUT now is there a way to put 2 small holes on each of the Larger flaps - so they will line up so you could run some twine or something thru it - hope this makes sense - but I would like to put 2 eyelets in each flap and run twine thru it - for a rustic type wedding invite
I have tried several times to line these up just not having luck and I am hoping some of you great people out there know of a simple way to do this
Cathy
PostPosted: Sat Jun 28, 2014 12:18 am
I am looking to make invitation card for my wedding party venue nyc. Please give me the best ideas for design and quotation of cards.
