If your design is too large to cut with your cutting machine, you can split up your design into tiles with the Pro version of Sure Cuts a Lot.
To create your tiles, choose Tiling from the Effects menu.
In the Settings, you can choose how the Columns and Rows will be created for the tiles.
If you set to Custom, you can manually add horizontal and vertical lines to designate the tiles.
Add a full horizontal tile line
Add a short horizontal line within a tile
Add a full vertical tile line
Add a short vertical tile line within a tile
To remove a tile, choose the Remove tool and then click within the tile you want to remove.
Instead of choosing Custom tiles, you can choose to have Evenly spaced tiles, and specify the number of columns and rows you want.
You can also choose a Fixed width and height for the tiles.
If you want the tiles to overlap, you check the Overlap option and specify how far to overlap.
When you are ready to cut, choose Cut to bring up the Cut window and click on the Tiles tab.
You can choose which tile you want to cut by clicking the Blade icon.
Tiling (Pro Version)
- Craft Edge
http://www.craftedge.com
Re: Tiling (Pro Version)
Thank you so much for your help. We will try this and see how it works with our machine.
I will check this out. Would make my life much easier.
