ISO- Inkscape tut on breaking apart a grouped svg file
sfandm
Post by sfandm »
I have tried this several ways and I can't do it. These are a group svg file, it says it at the bottom in Ink. The message at the bottom says:
Group of 4 objects in Layer 1.
I only want to use one of the objects in this group. Can someone tell me how to do this?
Thanks in advance.
GrammyKrausse
Re: ISO- Inkscape tut on breaking apart a grouped svg file
Post by GrammyKrausse »
Choose the ungroup function. Choose the object file then ungroup. If it is a svg pdf you may have to ungroup more then once but it will tell you in the message at the bottom of the screen.
firstcut
Post by firstcut »
Here is an awesome tip I learned from Heather M at this tutorial
http://imagesbyheatherm.wordpress.com/2 ... es-to-svg/
Hold down the control key and click with the selection (arrow) tool and you can select one item from a group.
Then you can copy and paste it to a new document or edit>invert selection and delete everything else.
sfandm
Post by sfandm »
Yeaaaaaaaa, Firstcut it worked. Thank you so much. Great tut.
