What am I doing wrong
I go into Inkscape and choose a Font. When I type "A" I get the dog dingbat that I want. I size it. I save it as an SVG file. I import it ito SCAL and it is blank. Thanks.
- Contact:
Re: What am I doing wrong
You have to convert it to path. From the menu, Path/Object to path.
after you type your text, you need to trace it.
type text
click: path: object to path
THEN save as an svg file.
if you do not trace the object/text, it will not work.
type text
- Contact:
You don't need Inkscape just to type in a dingbat, you can do that directly from SCAL.
