It is currently Mon Sep 23, 2019 3:20 am
PostPosted: Mon Sep 08, 2014 1:03 pm
Anytime I import an SVG (principally from Inkscape) the scale is wrong, something will be 3.9 in in inkscape, but 4.9in in eCal. I also tried pulling some SVGs from svgcut.com and they seem to be imported at a different scale also. Is there some kind of option I'm missing in either inkscape or ecal? This is really frustrating, i have to generate everything, then import, then re-adjust the size every time. It would be great if they just import at the same size they were designed in Inkscape.
Josh Patterson
PostPosted: Mon Sep 08, 2014 4:51 pm
There is a setting in the Preferences to set the svg dpi. It's a drop down box in the General tab. Set it to "90 (Inkscape)". HTH
My blog
PostPosted: Mon Sep 08, 2014 7:06 pm
Thank you so much I knew it must be something simple!
Josh
PostPosted: Sat Oct 13, 2018 2:18 am
yes this is right.
PostPosted: Sat May 18, 2019 1:55 pm
I instaled Inkscape v. 0.48. I ant to can import many files from Corel Draw.
I have a question.
Will look all files after import exactly like in the CorelDraw?
PostPosted: Sun May 19, 2019 8:17 am
They should be the same, although it's not unusual to need to resize to match the original export. But that's easy to do.
