Convert .png to SVG?
pkstew
Post by pkstew »
I have followed the tutorial from thefrugalcrafter but when I click "update" I am not seeing my graphic, just a white box? I appreciate any help that can be provided.
gj1
Re: Convert .png to SVG?
Post by gj1 »
I am not sure...but when I hear about a white box I think maybe you should go to View at the top and put a check mark by View outlines only.
But I don't know what and where 'update' is, so not sure if we are talking about the same thing.
gj1
Post by gj1 »
To change an .png in SCAL to an image to EXPORT for an .svg... are you using TRACE? Or you must be using INK. hmmm you have to adjust the brightness cutoff settings or color if it is color .png probably.
I did not watch the tutorial, sorry.
HeatherM
Post by HeatherM »
You are probably using Inkscape 0.48. It has a bug in the trace dialog. You can try closing, then re-opening Ink and you might be able to see the preview (but don't close the preview window until you are done tracing). Or you can download and install Inkscape 0.47 from here. http://sourceforge.net/projects/inkscap ... cape/0.47/
pkstew
Post by pkstew »
Ok thanks I will try these out.
