It is currently Sun Jan 20, 2019 2:35 am
PostPosted: Sat Nov 03, 2018 2:33 am
Good Morning
So i'm new to SCAL and my silver bullet after using a Cameo for the past 4 yrs.
Quick question... i have a wedding favour design that i have put together in silhouette comprising of print and cut (not silhouette files, all my own) when i save it as an svg and try to import it into SCAL my graphics are missing.... Am i missing something? or do i have to rebuild the designs in the SCAL Software.
I'd appreciate any help or advice with this... Thank you for taking the time to read.
Mel x
File comment: SVG File open in SCAL
File comment: SVG file open in silhouette
PostPosted: Sat Nov 03, 2018 8:37 am
In some cases the original graphic will be retained, but in others not. It appears that you can't keep the raster with SVG exports from Silhouette Studio. But if you still have the original graphic, you can easily import it into SCAL and then still import the SVG so that the cut lines will be there. Then align both, make sure the cut lines are on a lower level on the Layers Panel, select both and go to Object>Clip Path>Set Clip Path.
PostPosted: Sat Nov 03, 2018 10:41 am
Thank you, I’ll give this a try tomorrow. If I was to do my designs in adobe illustrator would I have the same problem or is it just the silhouette software?
PostPosted: Sat Nov 03, 2018 12:14 pm
More likely it's how Silhouette Studio is exporting the SVG. The reason I say that is you can import an SVG that has a traced image from Make The Cut or from Inkscape and it comes in perfectly. I don't have Illustrator so I can't test it. But I think it works okay because the product line I support, Klic-N-Kut, has a lot of customers who use Illustrator for designing and then cut from SCAL and no one has brought up this issue with me before.
PostPosted: Sat Nov 03, 2018 1:42 pm
Thank you for all your help. Moved across perfectly with adobe illustrator.
Really appreciate you taking the time to help me.
Mel x
PostPosted: Sat Nov 03, 2018 6:49 pm
I don't have AI anymore either, but I use Inkscape to create all of my files. As long as images are embedded in the svg file they show up along with the vectors when I bring the file into SCAL/eCAL.
My blog
