Best SVG Viewer
Best SVG Viewer
Please post what program you have had success with as a viewer and also note if it lets you print them as a catalog or printout. Your help would be greatly appreciated. Thanks!!
Re: Best SVG Viewer
Adobe Bridge CS3 is great. CS4 does not work, so research versions prior to purchasing, should you look at other versions. You can print catalogs, but I think you have to use another program to make it work right. I used to think that printing a catalog was the way to go, but you can assign key words and search based on them. This feature makes any viewer much more efficient than flipping through a printed catalog.
Re: Best SVG Viewer
I have problems with Bridge. I have an old computer that is nearing its end of life, and if I try to use it to view svg files in a folder with a lot of files in it, it seems to hang and doesn't finish loading the thumbnails. Of course better organization would help with that. The other nice thing about Bridge is that you can open your files in Inkscape through the preview in Bridge.
